Terry;
The valve covers look to be a lot taller than stock steel ones, is that correct???? If there are off the engine, could you take a couple of measurements for me????
With the cover upside down, measure from the outer lip (bottom of the cover) to the inside top of the cover on the long side and short side.......
I have roller rockers and a rocker stud girdle on my heads and can always use covers that are a little taller.....
Thanks;
David
DAVID GAGNARD
