Old 06-09-2006, 08:22 PM
jschiller's Avatar
jschiller jschiller is offline
Cobra Make, Engine: Past owner ERA 146, ERA 694 in progress, 428 CJ, toploader
Any Dana 44 will fit but if you are using a stock Jaguar open carrier, you may have to sleeve the ring gear bolts--the Jag has a thinner bolt and steel sleeves may be needed to take up the space. I replaced the entire open 2.88 center with a PowerLoc center and any Dana 44 is a bolt in replacement. There are bearing issues on the swap so you may have to be creative.
John
