Old 06-09-2006, 10:12 PM
jschiller's Avatar
jschiller jschiller is offline
Cobra Make, Engine: Past owner ERA 146, ERA 694 in progress, 428 CJ, toploader
Open carrier is a non posi unit--yes your XJS is a PowerLoc so no ring gear problems. The bearing problems can be diverse--I had a XJ6 open carrier diff that I swapped for a PowerLoc, I had it assembled by a local drivetrain shop and several of the so-called standard carrier bearings had to be substituted. I also had to have the outer pinion race seat milled a few thousandths to fit the pinion bearing race. The standard outer bearing that fit the pinion ok had a race that was bigger than the original one. That may have been due to the particular r&p I was using, I don't know. I purchased the used r&p separately. In any event it was a mix n match session for the bearings and races but it all went together in the end. My mistake was buying all the bearings in advance then not using half of them. Final assembly price was abt $600 parts and labor, still cheaper than a rebuilt Jag PowerLoc diff.
John
