Old 06-10-2006, 07:11 PM
Churchy Churchy is offline
Cobra Make, Engine: Classic Revival. LS1, T56, Billy Cart
Default Jag Front Sway Bar Mounting
Hi,
A lot of the CR guys now have a shiny red sway bar for the front of the Classic Revival. I got to thinking "how am I going to mount that to the Jag mounting points"
I knocked up this bracket and I think it will work.
I used the Ford bracket from the rears (cause that's what I had) and threaded an M12 mounting point to mount to the Jag bracket.
This Photo shows how it mounts.
It's only a prototype and I made it from Mild steel. I think it will be OK, but I'm a sparky and not all that clued up on mechanical design and load. If you guys that got the shiny red sway bars, have some suggestions, on what it should be made of, or is steel OK ?
I think the guy at Pedders may have some better connecting brackets (not the Ford one's). I will have a chat with them and see if I can come up with something that's not quite as big.
If it all works out, I am happy to make them for the gang who recently got sway bars.
