Old 06-10-2006, 07:19 PM
Jim Norris Jim Norris is offline
Cobra Make, Engine: SPF 2046; P.E. Aluminum 427 Windsor.
Default Another TKO 600 Problem
I have a TKO 600 with .64 5th. It works fine in every gear until I really push it. When I am pedal to the metal it will not go from third into fourth no matter what I do until the RPMs drop way back down. Anything less than WOT to redline (6000 rpm) works fine. It happens between fourth and fifth as well but never between first and second or second and third. I do not do a speed shift. I lift off the accelerator between each shift.
I wonder if it's a clutch problem or a tranny problem?
The clutch is hydraulic.
Any thoughts?
Jim
