Old 06-10-2006, 08:09 PM
OhBuoy OhBuoy is offline
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Well, I test fit the peices this afternoon. There is definately a peice missing, and I am not sure if I will end up modifying them. I have a battery cutoff mounted to the bulkhead, and this setup will limit access to that should it need work. I would need to drill out the rivets for that back panel. Also, same goes for the bolts for the seat belts, and considering they need to be swapped. I may order the panel that I am missing with a removable plate, or just modify what I have.
Tom
