Originally Posted by Rebel1
Gawd uncle Al, your missus kicks you outta bed, and you're not getting any so you come here to vent your anger.
So....in other words....build any engine you want. Get it thru an IM240 test and you can register it here in Queensland.
Wish it was as easy as it is to type it.
G'day Great Ungle (?) Les!
roflmao Mrs NASSTY had a giggle too!
She says 'ello to you too.
At least things seem to be heading in a favourable direction for you Qlder guys. From what I know, having O2 sensors, and a non misfiring ecu should be easy to do and hell the cats will do most of the work anyway. Most factory late model ecu's are now repreogrammable anyway (eg ls1 edit, Boss edit, au edit (EEC5)) My build needs to have an at idle smog test (donor production engine) and I know that the cats basically do all the work. It sounds as though the Qld burocrats are suggesting a model thats reasonably fair for everyone. If this model works out then us mexicans will need to jump on the band wagon as well.
btw I sent you an email on Saturday
