Old 06-11-2006, 03:27 PM
hssss's Avatar
hssss hssss is offline
Three Peaks I would be interested in names for redrilling Tbird hubs, was that 60 per hub or for both? If you haven’t already gotten the axles and shortened them already you might look at the Explorer shafts as I believe they are already shorter. I went by the Ford store yesterday to get what dimensions I could. The only thing I could find out is that the inner tire to inner tire on the explorer is 48". by extrapolating that seems like the axles might just be the right width. I plan on using an explorer housing with Torsen dif and 3.55s and MK VIII spindles with MK VII brakes and generally Rorty plans http://locost7.info/files/suspension...RSAssembly.pdf I'm building a 393 powered Lotus 7 which is generally the same as the Cobra but with a space frame. A lot of info can be gathered at http://locost7.info/mirror/mirror.php there are more similarities than differences.
