Old 06-12-2006, 12:09 PM
dsmith's Avatar
dsmith dsmith is offline
Cobra Make, Engine: ERA #63 428FE
Default check those gaskets again
Check those header to head gaskets again. Not going to tell you that this is the answer, but I had the exact same symptoms with my 428 and cured the entire situation, flames and all, with the header gasket change.
I couldn't find a good set of header gaskets without the bolt holes on the side until I spoke with Bob at ERA. Was able to get a solid set.
After instillation, no backfire - no flames
I do kinda miss those flames from time to time....
