I removed the exhaust for the third time now, and will have some exhaust gasket made to size with only the vertical holes. Hi temp silicone will go where the header pipes slip into the sidepipes. Will see if I finally get that popping sorted out.
I have read that the popping is actually a sign that the carburation is spot on and that it will not harm the engine nor the exhaust. Only the neighbours.
Nothing sounds better than a Cobra in a Tunnel !
