Old 06-12-2006, 08:13 PM
Dennis Kelley Dennis Kelley is offline
Cobra Make, Engine: BDR 302 AFR 165
Default Bg
Never could get mine to run for more than a day. Full of metal shavings and numerous other problems. REPEAT after me HOLLEY. I hate BG. Biggest rip off I ever received. My engine builder would not recomend them and I didn't listen to him and put on a speed demon. I replaced it with a simple HOLLEY 650 dp and the car picked up a .15 in the 1/8 mile and drove like a new car. Don't waste you money on a BG. No new carb should have to be rebuilt before you install it. I don't think summitt even carries them anymore because of the massive amount of returns. BG tech always says its your fault and is useless. I heard the increase your timing so much that I locked mine out at 34 degrees and still didn't help. I don't think BG tech has ever seen one of there as delivered carbs. Dynoed with both carbs Holley spanked it on the dyno and track. JMO
Later Dennis
