Bernie
Wow! 1.52 60 foot for a Cobra, that's great. Time for me to change tires,given up on those bill boards. Recommended rim for 3753R is 8.5", you're using 10", you think the over all diameter has been reduced that much from the 26" because of that? Also I guess you're using #6653 (26x10.00R15LT) fronts, rec. rim 8" you're good there, mine are 8.5" but I think rule of thumb plus or minus 1 inch of tread width so that will work. You say the ride is good with the LT front, I thought it might be a little harsh because it's made for a truck. I only get to see my car on the week-ends, last week when I opened the garage door to see another flat that's it no more Good Years. And the DOT issue on those tires has me concerned. What track did you get kicked off? I guess with 1.52 60 foot, you're in the full roll cage class.
Joe
