Old 06-14-2006, 04:05 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Michael,
Do the windshield yourself it is extrememly easy. Took me all of 30 mins to do mine. You can leave your side post in after you remove the 3 or 4 screws on the side, Then all you have is 2 or 3 screws that hold the windshield frame together. The glass slips out of the frame quite easily and all you do is remove the U shaped rubber from the edge of the old glass and re-use it on your new one and then put everything back together. You can do it by yourself but an extra set of hands would probably make you more comfortable. You may have some of the U shaped rubber stick around your old windshield but just use a single edge razor to get underneath that part to help you along.
Clois
"Let's roll"
"Be part of Something Good
