Thread: Jag Suspension
Old 06-15-2006, 06:00 PM
ZOERA-SC7XX's Avatar
ZOERA-SC7XX ZOERA-SC7XX is offline
As for the Jag rear, I got stuck BIG time...I bought a complete unit (it wasn't cheap) that was supposed to have a 3.36:1 ratio...it turned out to be a 2.88 (although it was posi). It also had both outer hub carriers cracked underneath, but were hidden by dirt & grease. I've since learned about the different rears/ratios and the difference between an open unit and a power-trac (posi) unit. DO YOUR HOMEWORK before you spend.
