Old 06-16-2006, 06:04 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
The difference between 7 and 10 degree keepers is quite obvious--10 won't go into 7 retainers and 7 are very loose in 10 retainers and will probably go thru.
What is more a problem is using keepers for the wrong size valve stems--3/8 on 11/32, etc
there are also keeper/retainer packages set up for different install heights( +/- .050 install heights) and also keepers for lash caps
Hope it helps, but I would take one apart to check it out.
Jerry
