Old 06-16-2006, 10:59 AM
tcams tcams is offline
Cobra Make, Engine: SPF 1821
Default SPF 1821 for sale
Superformance 427SC Cobra SPF#1821 (2004).
3,000 miles.
Indigo Blue/Viper Steel stripes, black leather interior.
Custom built 408 by P.A.E, www.paulsautomotiveengineering.com, with 570 hp/540 ft/lbs tq. Big block power from one of the baddest small blocks you’ll find. Victor jr, AFR 205’s 2.08 1.6, Comp Cams 236 intake, 245 exhaust, 825 Mighty Demon, MSD 6AL w/rev limiter. Untouchable power to weight ratio, but very easy to drive, only 10 to 1 compression, so fine on pump gas.
Custom 3” i.d. sidepipes built by Eric at Performance engineering, look identical, but incredible sound and more power than stock SPF pipes.
Tremec TKO 500 with 0.68:1 fifth gear (2500 rpm @75mph) and Centerforce dual friction clutch with limited-slip 3.73:1 rear axle.
15" Halibrand-style true knockoff wheels, with BFG Radial T/A rubber (255/60/15 front; 295/50/15 rear).
Other stuff: Upgraded Crystalite high intensity headlights with LightningWhite bulbs (you can actually see at night), soft top, hard side curtains, tonneau cover, leather steering wheel and all other Superformance standard features (gauges, willwoods, etc), plus glovebox, 4 Pt shoulder harnesses, sun visors, electrical cutoff switch, Superformance floormats and car cover, radiator bug screen and fire extinguisher. The car is in excellent condition, heated garage, never been wet. Over $65k invested, available for $57,000.
Contact Todd at (614) 226-8633, or email: todd.cameron@cardinal.com
Columbus, Ohio
Also listed on Cobra Country
