06-18-2006, 06:37 AM
6th Generation Texan
TX
A weak or bad wire/plug can fire when not under the high pressure of the cylinder.The high pressure/compression in the engine can prevent a weak spark from jumping the spark plug gap.
Put an ohm meter on the wires and watch the reading as you moved the wire and terminals around.
I betting on bad wires or terminals.
