Old 06-24-2006, 06:08 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Smile Pro Systems...The Best
I want to say thank you to Patrick at Pro System for the great service and great carb. I ordered a carb on Monday, a week ago, and Thursday of that week it arrived. When I opened the box, it was damaged in shipping, and I immediately called Patrick. He said no problem, he would build another carb and have UPS pick up this one. Next day UPS was at my door to pick up the carb, and 2 days later I had a new carb in hand.
I bolted the new carb on, set the float levels, adjusted the idle screws, and everthing ran fine. I then put the LM-1 A/F meter on. Adjusted the idle ratio to the high 14 range, then checked the other readings....cruise reading, in the high 13-14 range.....dropped down to the high 12 range when the main circuit kicked in....everything on this carb was dead on....right out of the box.
Again, thanks Patrick for the GREAT service.
Jack
XSSIVE .....
