Old 06-24-2006, 05:38 PM
Even if the pulleys are underdrive it sounds like the amp draw is WAY high and draining the system to quickly for pulley size to be a factor.
The fan motor does draw some serious amps. You could disconnect it when symptoms appear to see if that is the problem.
