Old 06-24-2006, 07:27 PM
mobilenuke mobilenuke is offline
Cobra Make, Engine: SPF136 427FE
Default more info
car cooled off and I went to see if it would start again--- no problem, it was charging as it should but reading at battery was only 12.8 up to 13.4 with rev.
Temp went up, fans kicked on, dropped ammeter-- disconnected first fan with a little improvement, disconnected second and went back to normal charging. Since this was a sudden change, worked fine day before, could there be a short in the fan switch or some other problem?
