Thread: Brake fluid
  #28 (permalink)
Old 06-25-2006, 10:56 PM
Nor Cal Al Nor Cal Al is offline
Cobra Make, Engine: Cobra-less
Just picked up on this thread. I have #128 and was told to use Dot 5 in the brakes and Dot 3 (or 4) on the clutch. I bled my clutch before the WSCBash and it came out black and heavy (sank to the bottom of the bleed bottle). Burned I assume from the header heat. I talked to Papa Frank at the Bash and he said to use synthetic DOT 3 in the clutch but I checked temperature ratings and am sticking with Castrol DOT 3/DOT 4. I am replacing my clutch master (from Summit) and rebuilding the actuator. Wrapped the clutch cyl with ceramic insulation.
Cobras Gone But Not Forgotten
