Old 06-26-2006, 07:50 AM
round_midnight round_midnight is offline
Cobra Make, Engine: BDR 187 Prism Red w/Silver stripes; 427 stroker by Smeding Performance, Tremec TKO600 gearbox
I went with what was recommended to me where I purchased the car (CA Cobra, now defunct), but I'm not sure an 11" disk would work with my flywheel. Anyway, I didn't know it was an option.
If it will clear the tunnel, the slave and bracket supplied with the car will work, I believe. You can just drill some holes in the bellhousing to mount it. I was going to do just that until I was told that it wouldn't fit. I would suggest that when mounting the bracket that you tap the holes in the bellhousing and thread the bolts through from the inside and secure them with Loctite. Then if you need to remove or adjust the bracket, you can just loosen the nuts and retighten them without having the bolts turn.
'round Midnight
You'll feel me coming
A new vibration
From afar you'll see me
I'm a sensation!
-Pete Townshend, Tommy
