If the heater isn't going to be really functional, why not just install a 12V muffin fan under the dash. I doubt they're going to hang around long enough to check for hot air. Just an idea.
Aside from that, I'd take the water either from the factory water pump nipple provided or from the back of the heads (drill/tap your intake manifold). I'd return the water to just below the thermostat; there should be a provision for this.
Taking the water from the back of the heads will do 2 things. 1. It will purge air that tends to get trapped back there in a cobra. 2. It will naturally drop the pressure and flow the core sees. It's not as convenient, however. Don't feel you have to do it this way; it's just a suggestion.
Incidentally, you might laugh if you saw what I'm using for defrost air. My cobra is supercharged and the bypass valve is constantly pumping vast amounts of slightly warm air out to atmosphere. Connect a hose from that to the heater/defroster and you've got one serious defrost system.
Byron
pictures on my site; project ludicrous speed.
www.racesystems.com
