Old 06-29-2006, 08:16 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Tommy
With the engine off and the clutch fully depressed, the shifter feels very stiff going from 1st to second and feels normal moving between other gears.
Do you think it could be the linkage binding? Chect the linkage to make sure the rods are not loose where they connect to the shifter/tranny. You could disconnect the linkage rods from the side of the tranny, and shift it manually to try to determine if it's in the trany vs. in the shifter/external to the tranny.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
