I port matched the carbs to the manifold. I found when mounting the carbs on the manifold as cast, the carb flange overlapped some of the edges on the manifold. A little work with a die grinder and some emery rolls smoothed things out.
What jet combination did you end up with, correctors, airs mains, etc?
 Snakebit
