Old 07-03-2006, 07:10 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
You say that you are referencing a tag, if so then you need to look at the engine to verify it. The heads have the # cast between the center exhaust ports and the block has it cast into the side. I can't reference the # you listed either, but often times the casting is not precise and is misread.
WDZ
