OK for a little taste,
Front end required, the inner and outer rack to be shortened.
The way you measure it is,
The distance between the lower control arm mounting bolts, centre to centre must be the same as the pivot points of the tie rod ends on the rack.
The rack must be at the same height as the lower control arm mounting points,the distance forward and back doesnt really matter.
Then the tie rods can be cut to lenght to suit.
I hope this makes sence.
I will post pic's next week when I have done mine.
Thanks
