Old 07-07-2006, 05:35 PM
edwhite7 edwhite7 is offline
Cobra Make, Engine: Contemporary, Shelby Alum 427, Dove heads
Don,t replace the master cylinder before checking the pedal free play. If the pedal is adjusted incorrectly the piston will block the port that connects the reservoir with the master cylinder. If this happens, and it happened to me, the fluid will expand and bring on the brakes. Their should be some play between your pedal and the piston in the master cylinder.
In school 90% is exceptional, in life 10% wrong is failure.
