Thread: brake fluid
  #21 (permalink)
Old 06-10-2001, 12:12 PM
coyled coyled is offline
I was running motil brake fluid. I am flushing it today and putting in the castrol srf. I am going to heat shield the masters(2 masters) and vent the front brakes. I can run the venting from the area in front of the radiator(allready a fresh air vent there on both sides to draw air from) or from the oblong ducts at the front of the cobra. Does it matter which way I go and where do you vent the air to? does it matter? the easiest way looks to be on the front top aimed at the inside of the rotor/vents. Any advice? scott
