1965 Backdraft 427 Cobra replica. Indigo Blue with White stripes. This was build #194 completed by Backdraft Racing in 2005. Under the hood you will find a Ford Motorsports 392 stroker that delivers over 430 hp and 450 lb. ft. torque. This setup comes with a 770 Holley Street Avenger Carb, Canton 9 qt
oil pan, Mocal
oil cooler, MSD 6AL ignition, K&N
oil, air and valve filter, McLeod Steel bellhousing, Tremec TKO 500 transmission, BMW IRS w/3:10 gears, 4-wheel power disc brakes, 17” Halibrand-style wheels fitted with Nitto tires 315/35R17 17" rear and 245/45ZR17 17" in the front.
In the cockpit you will find AutoMeter Vintage Series gauges, black leather interior, chrome fire extinguisher and windshield mounted chromed Raydot-style mirror with polished bracket. Finish Line roll bar bezels, Finish Line license plate bracket, Optima Red Top battery with Finish Line billet battery box and California indoor car cover.
The underside of the hood scoop has been
autographed by none other then
Carroll Shelby. Carroll’s signature has been clear-coated and you will also get a Certificate of Authenticity to prove that this signature is real so that you can protect this investment. This car is titled in Minnesota as a 1965 Roadster-which is E-Check exempt.
SOLD
Please send me an email if you would like to see pictures.
