Old 07-11-2006, 07:57 AM
Barry_R Barry_R is offline
Default (5) 428 blocks, 4.25 balanced crank & rods, CNC'd heads, etc...
I found something I really want to own...so I am going to sell some stuff to see if I can gather up the needed coin. I don't really want to but...here goes...I reserve the right to change my mind with a minute's notice...
I have five industrial 428 blocks. One is standard bore. One is standard bore but has a split wall requiring a single sleeve. The other three are .030 over and look decent - might even clean up at .035. Make rational offers for them one at a time or get an extra for the little lady....
I am selling the crank and rods from my Engine Master's entry. It is a Scat 4.25 ductile crank, 6.700 rods, and neutral balanced with mallory for a 760 gram piston/pin assembly. Should be within tweaking/drilling range for most any rational combination without adding any extra metal.
$1200 for the set.
One of our forum members has been waiting for an eternity to get a set of Blue Thunder heads CNC'd. To get my pals at ET off the dime I committed to do five sets of the heads at once. Three pair are spoken for, but in a very short time I will have two extra sets of Blue Thunder small bore medium riser CNC ported heads ready to ship for $2820/pr. These are very similar to the ones on my Engine Masters FE that made 752HP on 91 octane.
In addition I have one set of Blue Thunder medium riser CNC ported large bore heads ready as well - - these have huge steel inserts added to reinforce the rocker stud mounts for serious roller cam springs, and come with Ferrea stainless valves. These are still on an engine, have seen very limited dyno and track time (est. 20 pulls, 20 passes), and are in excellent condition. $2800/pr.
Buy a block, get it machined, buy the rotating stuff, add the heads. That combo will make you a hero!
Shipping at your expense. Rational offers considered.
Call at (248) 931-0358
