Old 07-13-2006, 03:03 AM
bermblaster41 bermblaster41 is offline
Cobra Make, Engine: Hurricane Motosports
Alot of the panels on aircraft are put inplace with adhiesive and then riveted for strength and to prevent the panel from working loose do to flex and vibration. I purchaced my kit partially put together. I will be taking it all the way down to bare frame and putting all rivets in wet {with sealant} with a film of sealant between panel and frame . This will cut down panel rattle to a minimum and seal out moisture. Hope this helps Berm!
