Old 07-15-2006, 08:11 AM
CheeseSnake CheeseSnake is offline
Default Wheel & tire combo's
Don,
My kit is a 1991, with the standard M2 front suspension and 8.8" rear. I bought the following from you a couple of months ago, and want to make sure everything will fit before I order new wheels and tires for the rear;
Front;
Bought from CR;
- Tubular upper and lower control arms, lowers eliminate the radius rod.
- Power brake master, booster and adjustable prop valve.
- Coilovers with Pro-shocks.
Already has M2 disc brakes in front, which will probably get changed out to Wilwood 10-3/4" in future. Current wheels and tires are 8x15 with (I believe) 3-3/4" backspace with P235-60-15. I want to keep the wheels and put P245-60-15 tires on them.
Rear;
Bought from CR;
- Rear coilovers with Pro-shocks.
- Disc brake conversion.
Car has an 8.8" rear, already removed the screw adjuster, boxed the upper and lower arms, and removed the coil perches from the lower arms. Current wheel/tire combo is 8x15 with I believe 3-3/4" backspace and P255-60-15's. I want to order 9-1/2x15 wheels and mount P295-50-15 tires. Will these fit, and do I have to complete the rear disc conversion b4 they will fit? Car currently has the standard Ford drums.
I am getting ready to put the rear back together today, then on to the front suspension. I want to make sure the wheel/tire combo's will fit before I order new front tires and rear wheels and tires.
