Old 07-18-2006, 05:32 AM
COBRA406 COBRA406 is offline
Cobra Make, Engine: MIDSTATES, 408C
No 351C's in Ford trucks, just 351M/400's. M's and 400's are a dime a
dozen. Unless there are tags or stickers on the M or 400, you would
have to pull the pan and check the crank ID because the M and 400
are identical externally and the only difference is the crank and pistons.
Good luck. The M/400 have a taller and wider block and intake manifold
than the C.
Hope this helps,
Bob T.
