I normally use the Edelbrock Performer RPM manifold. That is the tallest manifold I can get under the hood. The large oval air cleaner will need to be modified to fit under the scoop. It sits a little too far forward to clear the scoop. I modify them by cutting out the base carb opening and moving it about 2" back. The smaller oval air cleaner will fit ok.
Don
