Troy,
No problems, I can certainly make a set for you.
It may be a little delayed, as we are rebuilding the engine and I do not want to get little bits of aluminium floating around the garage whilst the engine is a block and lots of other little bits that I have to work out where to put them.
So once the engine is back together and sealed, I can start up the lath and mill again. Should be around the middle of August (hopefully).
