Since the frame rails come out more or less on center under your seat I made my own mounts that slide over the frame rail and bolt to the frame. I placed one on each side of the main rails just above where the frame starts it rise over the axle. The second set are on the part of the horizontal part of the frame the runs over the top of the axle.
If you were to imagine a roman number 2 missing the bottom horizontal line that would be what my mounts looked like.
Once you set the body and have it where you want it you can raise these mounts up to the body and bolt them to the frame. They also then act as body mounts.
If I get a chance and can figure out how I will try to post a picture..
Good Luck,
Aaron
