Old 07-24-2006, 09:26 PM
JAM1775 JAM1775 is offline
Cobra Make, Engine: SPF 974
Pistons are good . What compression are you running?
What octane fuel is available to you ?
What heads are you using ?
I'm running 11:1 with Brodix heads 351W on 93 octane with 75HP EDL carb system. No problem with 3 degrees taken out , used in 3rd/4th gears only.
I did up it to 100HP with 4 degrees but the car got a little squirrely in 3rd gear on the street. Backed down to 75's.
