Old 07-25-2006, 06:01 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Ken
Does your carb have a 1/4 or a 5/16 aircleaner stud? The ones with a 5/16 stud have a idle speed adjustment valve in the center of the base plate accessable thru the stud hole---If you have a 1/4 stud you won't have the adjuster valve but can either send the base plate to Demon for mods or can machine a couple of grooves in an X pattern on the top side of the base plate where it mates with the main body and drill a 1/8 hole thru the center to allow extra air for idle. All od the Demon carbs that I've worked on have been full of machining chips in about every nook and cranny---I don't think BG has a aircompressor so they can blow the chips out before assembly--
Jerry
