Old 07-26-2006, 06:26 AM
mj_duell mj_duell is offline
I contributed to CC in 2006
I have in the past contributed to CC
Send a message via AIM to mj_duell
Default TTR/GT First two packages.
Hi Guys,
I have been working with Don from D&D for the last week on packages for the TTR/GT. We have the first 2 designed and I will have them on our site with details by the weekend. There will be two more higher level packages that include additional pieces coming shortly. Here is a listing of the first two:
"Base Package" $20,995.00
GT Technology Tubular Space Frame, Powder coated gloss black (other colors including
metallics available as option)
Complete Body / Front, Back, Roof, Doors, Rockers, Dash
Full Set of Aluminum panels bent and set in place
Windshield, Lexan Headlight Covers, Side Windows
Space tube Rear Chassis Brace
Tubular Front Suspension Upper and Lower Control arms.
Tubular Rear Suspension Upper and Lower Control arms.
Teflon Spherical rod ends and tubular Rod links etc.
"Roller Package 1" $29,995.00
This package is designed as a complete rolling chassis, brakes and body. It's perfect for those wanting to build track cars that will not require a long list of accessories or for builders who wish to do the replica in stages.
Base Package listed above
Ford or Chevy Engine Mounts
Coil-over Shocks & Springs
High Performance Wheel Bearings
Steering Column, Rack and Pinion and Tie-Rod ends
Sealed Bearing Universal Joints
Splined Quick Release Steering
Vintage Type Steering Wheel
Wilwood Four Piston Front Brake Calipers
Wilwood Four Piston RearBrake Calipers
Wilwood 11.75" Rotors
Vintage Wheel Company Knock-Off Style Wheels with Adapters
15 X 8 (Front)
15 X 10 (Rear)
295-50-15 Rear Radial Tires
235-60-15 Front Radial Tires
*Optional AVON Vintage tires
Custom 600 h.p. Aluminum Radiator
Electric Cooling Fans
Twin Fuel Tanks
*Note Introductory rollers will get a free powder-coated 6-point roll cage. We also have optional Gulf flares.
Post your questions on this thread or send me an email. I will be happy to answer any questions that I can.
--Mike / Turn Ten Racing, Inc.
