Originally Posted by dscott
I normally use the Edelbrock Performer RPM manifold. That is the tallest manifold I can get under the hood. The large oval air cleaner will need to be modified to fit under the scoop. It sits a little too far forward to clear the scoop. I modify them by cutting out the base carb opening and moving it about 2" back. The smaller oval air cleaner will fit ok.
Don
How exactly do you modify the larger one.. Its all cast is it not?? Got pics??
