Old 07-28-2006, 10:39 PM
fastraxsg's Avatar
fastraxsg fastraxsg is offline
Evryday is a roadstr day
Cobra Make, Engine: RHD Hurricane street roadster HM1081 aging nicely in the garage
As you two are some of the more prolific builders and posters, I could sure use some advice. I have this ratty old sorta cobra car that was built locally on a Torana pan with 202 six and a trimatic. I dearly would love to build a proper replica but with customs and import problems and registration it will not happen. However, I can get in a body and bits shipped in but no chassis or motor. This is what I have been thinking, I can buy a second hand Holden belmont wagon or Kingswood SL and use the suspension from it, chop the frame to fit the right wheel base and get a three bar set up somewhere or four bar and use that for the rear. I also have an oppurtunity to get a Chevy 302 with complete front and rear suspension, auto trans (I've got a stuffed left knee so no clutch) driveshaft and diff. You have mentioned build manuals before, are these the books that come with kits or has someone written a manual on do it yourself at home chassis work. My welding isn't so hot, I can gas weld, but a bit slack on the arc welding but can get that done easy enough.
By using the old Holden, I can use the registration, legally change the motor type to a V-8 and have correct serial numbers which is about all they care about. Plus the road tax is still cheap, about $30 Aust a year.
I know there were pixs of a car that someone was building up with Holden front suspension, is this common in Aust? Any help you guys can pass along would be great.
aka Fuzzy ............... "It is not the return ON my investment that I am concerned about; it is the return OF my investment".......from Will Rogers
