Old 07-29-2006, 07:42 PM
silverback silverback is offline
Cobra Make, Engine: original a/c. shell valley 427. daytona coupe
channel for youre rubber seal on the rear main bearing cap. I would try it with some 3-m yellow adhesive between the cap and rubber and then normal silicone in the corners where the rest of the pan gasket meets it. if the pan fits tight when the rubber is compressed it shouldnt move or leak. If there is a leak it will come from the main seal.
