Thread: Best Fe Parts.
Old 07-30-2006, 11:20 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Originally Posted by Excaliber
I noticed the Tunnel Wedge pictured above will also require a valley pan.
The 'valley pan' is just a flat piece of sheetmetal that's screwed onto the intake from the bottom.
nvr2muchpwr, the teardrop on your hood was originally made to clear a high riser setup. You might look into some ported Edelbrock or Blue Thunder heads, depending on your budget. You can make 650 hp or more with the right parts.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
