Old 07-31-2006, 06:24 AM
flwolfman's Avatar
flwolfman flwolfman is offline
Cobra Make, Engine: None at moment
If you ground the wire going to the sending unit, the gauge should go to full. This will tell you if the gauge is workiing or not. Also, you can take the sending unit out of the tank and use an ohm meter on the sending unit to test it. The resistance should change when you move the float arm up and down. Good luck. I have to do the same with a 57 T Bird today. Jim
