Old 08-01-2006, 10:18 AM
WOLFEMAN's Avatar
WOLFEMAN WOLFEMAN is offline
Cobra Make, Engine: BDR#369 392/TKO
Default BDR Front Suspension Adjustment
It appears that the factory springs are too short if I adjust the bottom adjustment so the front end rides lower. There is a large gap when it's on the jack (in fact, I have to manually align the spring when I take the car off the jack so the coil is properly aligned). I'm afraid that, even though they compress when the weight of the car is on the wheels, a hard drive over large bumps may cause handling problems.
Am I missing something? Is the top adjustable as well? Do I need longer springs.
