  #983 (permalink)
Old 08-04-2006, 09:58 AM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Ron and Tru
3 way Lucas switch on dash has been checked and working properly (connectivity). Off is OK. Middle position is the running lights which is part of the sealed beam lights, and it works OK. But when the switch is flipped to the third position, the low beams do NOT illuminate. But the running lights do stay ON.
But, when you click on the high beam switch, the high beam lights do come ON, but when you let go of the switch (which is built into the turn signal stalk), the high beams go out and you only have the running lights on.
The headlight relay switch has been replaced and all the fuses are OK.
I just have to time my cruise night to make sure I get home by 8:00 PM
Its been like this for about 4 weeks. I'm about to take the car to a friend of mine - "Mr. Wires". I'd hate to take the column apart.
Warren
