  #34 (permalink)
Old 08-05-2006, 10:27 AM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default Do tell.....
Originally Posted by Power Surge
Hehe, yeah. I spent a LOT of time and effort on that motor, making sure every nut, every bolt, every wire, bracket, clamp, etc was as correct to an original as I could. Lots of photos, questions, and buying wrong parts . But I am really happy with how it came out. Other than the obvious block difference (it's a 390), the rest of the motor is pretty much exact to an original (save for one or two items I haven't changed yet).
Power Surge,
Can you share the details on your "original" engine build? It would be interesting and informative to hear about what you found through your research. For example, given my recent trials with blow-by, I'm curious to hear how that was addressed on original engines. Was the only venting the oil recovery tank on the firewall with a line from the rear breather hole on the intake? How did those oil tanks work? Did you just have to empty them, or did the oil run back in to the crankcase?
Thanks!
Scott
