Old 08-06-2006, 10:48 PM
LMH's Avatar
LMH LMH is offline
My opnion on vaccum advance is that street cars should use them.
You should use a dist drive gear recommended by the cam manufacturer for your cam. In this case, you probably will want a steel gear ( I'm not a fan of bronze) for the roller cam but check with Comp Cams to be sure.
So if it were me, I'd buy the vacuum adv dist and change the gear.
