Thread: Oil pressure 0
Old 08-07-2006, 11:50 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
If you're looking for oil in the heads, it depends on if there's an oil restrictor installed; with an oil restrictor, the heads won't get "flooded" with oil, just a small flow dripping off the stamped steel parts. You should feel a definite drag on the drill motor when turning the oil pump shaft counterclockwise. FYI, if you have a spare distributor, strip it down to just the main shaft and use that to turn the oil pump shaft.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
